Originally Posted by jonyjoe101
I bought the cheapest starter at autozone for my astrovan 2 years ago (95 dollars), it still working good. But I also kept the old starter (since it wasnt the starter that was bad).
I was getting no cranking(or clicking) from the starter, thats why I bought a new starter. The battery was good, even tried a different battery. When replaced the starter it still wouldnt crank over. Replaced the ignition switch, and then the neutral safety switch which didnt fix it. I had to rig a toggle switch so I could hotwire it to start for the past 2 years, finally found it was the ignition lock cylinder that was causing the problem.
If your going to be offroading in secluded areas then it might be worthwhile to spend extra for high quality parts.
This is what scares me.
Long story, came back from diving in southeast Asia. Left van at repair shop to be worked on. $75 taxi to shop with bags in flip flops, 10 degrees and a foot of snow. No biggy, start it up and drive home.
Van would not start, no propane in van as I didn't need it. I giggled battery cables, couldn't find anything to tap on starter if I even had someone to hold the key in start position. No screwdriver to jump solenoid. FREEZING MY AZZ OFF! Guy was at work with full time job ... I just had to go. $100 taxi ride to home after waiting for taxi to show up!!!
Mechanic said he simple held key in the start position for 30 seconds and it eventually fired up. I'm thinking flat spot on armature/brushes? All I know is no problems starting ALL last winter or up until 3 days ago. It clicks once Battery is good, cable connections are good.
Mechanic told me when this happened 2 yrs ago, if it happens again ... replace the starter.
BUT, what if it's ignition switch, connections elsewhere, yada, yada.
After having it plugged in (block heater) for 2 days, it fired right up.
I'm still leaning towards starter.
