Originally Posted by SwiftRaven
I am replacing the original AGM batteries with Lithium. Should be somewhat straight forward. Right? Wrong! Sportsmobile in Indiana built the Van and when it came to documenting the wiring they did nothing. No wires are labeled, only 1 buss, all other connections are bolted together and tapped, no battery or load shutoff switches. So disappointing. As a result I am tracking down every wire. Have a look:
That's pretty standard for any RV converter in my experience. About the best you can hope to find in the way of labeling is just at the house fuse box.
Good luck! If anyone here can help you Greg can.
