If the "replaced" interior bulbs were incandescent, then intermittent operation might not be too much of a surprise, as coiled tungsten filaments are a little bit springy, but ultimately made of a brittle material. If the electric arc briefly formed when the bulb burns out during operation isn't enough to melt the tungsten back sufficiently on both sides, the result can be intermittent contact between the recently freed ends of the filament that will occasionally weld themselves again (poorly) until a big enough jolt breaks the ends of the filament free again.
And if one is a serious off-roader, vibration alone can cause incandescent bulb failures even when the bulb is off, especially in interior light fixtures that may accentuate the vibration through resonance, etc.
On the other hand, if the "replaced" bulbs were already LED-type, then you might want to go looking for intermittent bulb socket contacts, "iffy" splices, and worn-out switches.
So maybe this is a surprise, and then again, maybe it's something else. I'm sure you'll determine this with some certainty over the long haul . . .
(Just my two cents minus a nickel.)
Timerider
"Silver Kitten": 2002 E-350 7.3 RB-50 SMB Quigley 4x4, Agile RIP-kit
"My Metal Mistress": 1982 Cessna T182 - "Sleeps 0, but leaps tall mountains in a single bound."
