So I have a small, 100 watt panel I'd like to hard mount for passive charging of my house batteries.
It's one of the flexible Renogy panels that I pilfered from another project.
I'm thinking towards the rear is the smartest move, bu am open to ideas.
What's the easiest place to run wiring from the pop top with the least risk of a leak?
SMB generally runs wire up to the top of the penthouse via same corrugated loom. Theses are usually found in the passenger rear corner or driver front corner. This is usually a good path for a pair of solar wires. The wires can side between canvas and top so that they are outside of the inside area. You can then go through the top on the outside of the protected area so there is less chance of a leak getting inside the van.
