02-27-2018, 09:48 AM
Total shut-down while driving
I was making a turn from a turning lane onto a side road between Goldfield and Tonopah last week and midway through the turn my engine shut down completely, total loss of power. No warning. I was able to complete the turn (without power steering) and pull over. I then put it in park and turned the key off. A moment later I turned the key and everything came back on again like nothing was wrong.
After getting home to SLC I've not driven it, but plan to take it to a mechanic today. But I wondered if anyone had thoughts about causes. I've had previous problems with the throttle and filters causing hesitation during acceleration(fixed, mostly), but this was just a total shutdown, creepy when it happened.
By the way, there's an awesome hot spring just off Silver Peak road.
Scott
02-27-2018, 10:07 AM
What motor? In my case, sudden death of the motor was caused by the fuel pump in the tank. I replaced a couple actually. Good luck..........
02-27-2018, 10:33 AM
Check your battery terminals. A momentary loss of of connection can kill the motor, especially if the alternator was not generating because it was running too hot from compensating for the loose connection.
02-27-2018, 10:40 AM
whoah that is scary!
John
02-27-2018, 10:46 AM
Missing some pertinent info.
As mentioned, what motor, any gadgets, bolt-ons, reflash, obd2 stuff?
Rob.
Current:
And had three other E350s...
02-27-2018, 10:51 AM
It's a 2001 E-350 V8, 5.4lt. I'll check the terminals now.
02-27-2018, 11:21 AM
Everything seems to work just fine now, visible connections look solid. But it kind of leaves you wondering if and when it could happen again. I'm going to test-load a pic here too just to see if I've re-mastered how to do that.
02-27-2018, 11:35 AM
My 2001 5.4 did the exact same thing a few times. After a few stalls / no starts over a period of a couple months, it suddenly gave up completely, requiring a tow. Check the output pressure for the fuel pump. There is a fitting on the fuel rail you can screw a gauge to and you can borrow a gauge from an auto parts store. I think minimum pressure is about 20lbs but don't quote me on that. I've replaced the pump more than once, it's a pretty crappy design and I now carry a spare.
02-27-2018, 04:46 PM
I got it. You've been putting gas in your 6.0 diesel thinking it was a 5.4l. Put gas in it from now on. 5.4's don't break.
However, if it did, it's probably the fuel pump.
02-27-2018, 05:16 PM
Originally Posted by 86Scotty
I got it. 5.4's don't break.
I have to agree with you that the 5.4's don't break. Diesels on the other hand Oops, I've done it again, will I get banned if I keep bashing diesels?
