About a year in, one of the arms stopped closing smoothly, I had to jiggle it closed one notch at a time. I mis-diagnosed the failure and contacted customer support for a replacement part I couldn't find on their website. They very helpfully replied with the correct diagnosis, the fix, and a nice image to make it clear. The problem does occasionally recur, but is easy to fix again.
This was their reply, if anyone else needs it:
Please loosen the bolt in the diagram a ¼ - ½ of a turn. If the bolt is too tight or is binding in the hole it will apply top pressure on the cam-locking mechanism not allowing it to function properly.
