Old 01-08-2020, 08:50 AM   #1
Body Mount Count
I have a 2010 E350 XLT Extented body cargo van, I am looking to buy new body mounts and all I seem to find is 6 positions total of 12 mounts. My truck has 7 spots? What gives? Is one of the positions NOT considered a body mount? Confused!
Megalovon is offline   Reply With Quote
Old 01-17-2020, 05:39 PM   #2
Mega, this guy has the best info on a body lift for our vans.
He made his but it seems fairly simple.
https://www.thedieselstop.com/thread...1-lift.115346/
Pics in the link at the top of the thread.
Info as you read down.
Old 01-20-2020, 09:13 AM   #3
I finally stopped by the local Ford dealer to confirm the number of body mounts, there are 14 on my EB. What was confusing was that all the after market sources were telling me there were only 12 mounts, they were wrong! Positions 1 and 5 are unique, all the other positions are common, so long story short if you have an EB you have to buy 2 extra common mounts. I just ordered my mounts and haven't received them yet, if I come up with any other surprises I will post.
Old 01-20-2020, 09:37 AM   #4
From the link above.
My van is extended type---I used 14pcs of 3 1/2 round by 1 thick by 3/8 hole in center and 2pcs of 3in round by 1in thick by 3/8threaded. The extended van needs the 3in block standard van does not need
Old 01-20-2020, 10:00 AM   #5
I bought new Dorman mounts from Rock auto $450, Ford dealership wanted $850!
Old 01-20-2020, 05:43 PM   #6
Mikerson's Avatar
Thanks for the info megalovon. Can you post part numbers and their locations?
Mikerson is offline   Reply With Quote
Old 01-21-2020, 08:18 AM   #7
Once I install them and know for sure everything is correct I will post all part numbers and I also have a diagram from Ford with locations.
Old 01-23-2020, 07:06 AM   #8
Diagram and part #s
I attached a diagram from Ford along with their parts list, I also wrote down the Dorman part numbers that I ordered. I believe I converted the part numbers correctly, wont be 100% sure until I mount the body back on which wont happen til spring. If anyone see's an error please let me know.
Old 02-18-2021, 01:57 PM   #9
VMCFred's Avatar
Everything worked out as planned? I'm also about to replace all body mounts and I'm a bit confused because I'm counting 7 portions in your diagram not 6 portions.
Thanks
Fred
Fred
Camper, Powerstroke Fan
2005 Ford E350 4x4 6.0
VMCFred is offline   Reply With Quote
Old 03-05-2023, 08:34 AM   #10
Good Morning!
Just reading this thread as I‘m about to renew my floor.
As I have access to all body mounts I‘m planning on replacing them after 280k miles [emoji23]
Can someone share his experience how it works? From what I understand I have to remove the fuel inlet, then loosen up all body mounts, lift the body up by 1/2“ and swap em out?! Is that all?
I also watched a video on youtube for F-series and they mentioned not to use an impact?!
Any insight/ video/ warning welcome!
