Originally Posted by rpoole
I think you've got a terrific idea, maybe a second gig here! I've got a E350 regular body passenger full of windows. Would this still work? In your pictures, how is the carpet attached to the plywood?
It’s a automotive grade tweed material. Not carpet on the plywood. I used “flexform” carpet around the perimeter and the pillars. It spray tacked to the plywood. If you have windows you’ll need to install nailers around the windows with a glue or epoxy to the metal to screw the ply wood to. You will need to cut out your widows obviously .
