A little more progress on the Super Duty mirror project....
I got some waterjet parts for the mounting base and welded up the passenger side mount. Worked out pretty good. Very solid and pretty easy to put together.
I've cut down the truck mirror plastic shroud to rough out the design for the van. I'm about as far as I can go on my busted-a$$ wrecking yard door because it is pretty banged up in some important areas and I can't build an accurate model off of a crushed door. I need to pull my van into the shop, mount up the mirror and start filling in the voids and shaping some plastic.
If I had a CAD model of the door this would be super easy and I'd just build a shroud in Solidworks. Anyone out there have a CAD model of the door? They're available to members of SAE and various aftermarket manufacturers and conversion companies probably have them as well.
