Old 01-08-2011, 09:16 PM   #31
Re: new van build
She's pretty big
Van sits on 33's and the 4x4 conversion adds 3 or 4 inches
Tundra sits on 34's with a 4 inch lift
2003 Ford E350 7.3 Diesel 15 Passenger Van | CCV Pop Top | Quigley 4x4 |
sledmods is offline   Reply With Quote
Old 01-09-2011, 07:02 PM   #32
Re: new van build
I see the top latches are external. To me, the internal latches on an SMB are one of the better features. Our old popup pickup camper had external latches. Hated to get out in the rain to unlock the top so it could be raised. Of course I also hated to get out in the rain to get into the camper through the back door.
Old 01-09-2011, 09:21 PM   #33
Re: new van build
I opted for external latches. It creates a better seal
Old 01-10-2011, 11:49 AM   #34
Re: new van build
Is internal latching the standard setup?
Old 01-10-2011, 12:28 PM   #35
Re: new van build
i'll let Derek give an official answer but from my understanding it depends on your build. Your bed design may prevent internal latches. If the van isn't going to see to much off road use you can probably get away with NO latches because the actuators pull the top down tight.
Old 01-10-2011, 01:22 PM   #36
Re: new van build
I wouldn't want to test that on the freeway...
Old 01-10-2011, 03:10 PM   #37
Re: new van build
instant convertible.
racrx451 is offline   Reply With Quote
Old 01-10-2011, 03:23 PM   #38
Re: new van build
Oh, you're right. I remember now that all his tops are electrically raised/lowered. If he is using a standard screw lift, it can't be opened unless the motor does it.
Old 01-11-2011, 12:57 PM   #39
Re: new van build
You can chose between interior or exterior latches, exterior are simpler, cleaner and hold better, hands down.
I ran my van with no latches and it worked fine on the road but after long harsh trail trips I noticed some
rubbing occuring where the body and top meet so I cured that with latches and a different seal design like
the one on sledmods van. You can also do an interior latch like a smb but it is more complicated and not as
appealing to look at. All of my tops go up and down using an electric motor for several reasons but the main
ones are, if you load down your top or put a roof rack on it you do not have to unload it to pop the top,
If it snows while you are sleeping you do not have to worry about getting smashed in your bed while sleeping.
I have had 5 adults standing on my while it was in the up position that is how strong they are when they are up.
Smb has a patent on there spring loaded scissor design and even though it is about to run out I do not feel it is a stout enough design for me to sell.
Since the tops are operated using a key fob you can walk around the van while you lower or raise it to be sure nothing is getting pinched during the process.
I get asked what if a motor fails, first I have not had one fail yet, even though I know it is a matter of time. if
one does fail you can remove 1 bolt and lower and raise it by physical strength. I do not recommend this however
you will never get stuck in a camping spot with your top up. Also I cannot imagine a actuator failing when it is lowering a top all of the stress occurs during the first 5 inches of the lift, so chances are if it failed it would still lower. I do not know this for sure it is just speculation I will find out when one actually fails.
Derek
https://WWW.COLORADOCAMPERVAN.COM
00 PSD EB Quigly being converted to a Colorado Camper Van top
73 ford e100 soon to be 4wd with a 4bt
72 bronco aod injected 351 4 linked arb f/r 38in swampers
72 bronco 302 c4 soon to be 4bt w/ 5speed 4 inch lift 33 swampers
81 cj 7 in pieces at the moment injected twin turbo 401
ktm 525 exc, 620sx,
62 caddy convertible waiting for me to install 2007 northstar
dsw4x4 is offline   Reply With Quote
Old 01-11-2011, 01:20 PM   #40
Roonie's Avatar
Re: new van build
Can you add your lift system to the SMB tops? I have been wanting to change mine from manual to electric. If you can convert them about how much would it cost?
