Now that so much of the busy work on refinishing the rack is done, it's time to get the brackets put together.
I started by taking a piece of c-channel steel and cutting down about 1/2 of one edge with the plasma torch. Then I used a grinder to smooth the edges. The guy cutting in the picture isn't me, he's the guy I'm sharing shop space with to get access to the metal working tools.
Then I sliced it up into 6 brackets and drilled some holes.
A test fit exposed two problems. The first was that the edge needed to be cut down more than the half way... The second problem was the length of the bolts I picked up... they get in the way of the van doors.
So I took the grinder to it and just completely removed the edge making it more of an "L" channel... I forgot to snap a photo of the test fit, but I think it'll work just fine.
I got some primer and a coat of paint on it tonight and will need to apply a few more tomorrow. I still need to cut some rubber to go between the mounts and the van. All that and some new bolts and I should be set!
