Old 08-19-2020, 08:33 PM   #31
SheepShagger's Avatar
Originally Posted by Chinook View Post
Have you done some research into how tall the sienna seats are from bottom of the seat to the top of the butt cushion when compared to your ford seats? If you sit your ford seat on the floor next to the sienna seat, the sienna seat is taller measuring from the floor to the top of the seat cushion.
Then you have to make sure the seats are centered in the truck properly so if the air bag deploys in an accident it doesnt knock your head threw the side window or something odd.
You missed probably the most important point. Seatbelt clasp is identical between the two, but the Ford clasp has a tensioner in it set to activate on airbag deploy where as the sienna doesn’t. So there is some modification that needs to be made to the sienna seat to make the Ford clasp fit. But yes, you can make the sienna fit in the perfect location, while “just” missing the B pillar.
Old 08-20-2020, 09:30 AM   #32
VanDam's Avatar
Originally Posted by SheepShagger View Post
Not swivel, but I did the first Sienna conversion into ford E350 10 years ago. Used RV electric bases for the front, it’s not hard to make your own as long as you’re prepared to strip the seats down and have access to a welder.
https://www.sportsmobileforum.com/fo...eats-5547.html
Thanks for the reply. My van already has a power driver base. Plan is to mount a swivel and create my own brackets for the sienna seats. I’ll track the process and see if I can make something work.
2004.5 Ford E350, Clydesdale 4x4 Conversion, head studs, egr delete, SCT tuner/monitor, much more to come..
VanDam is offline   Reply With Quote
Old 08-31-2020, 11:16 AM   #33
I will be following this thread closely.
Looking forward to hear how you did it and what all is involved
JSO
jso5000 is offline   Reply With Quote
Old 09-06-2020, 10:29 PM   #34
Drivers side installed on 6 way electric sliders.
Chinook is offline   Reply With Quote
Tags
front, sienna, swivel
Guster
Salmon
The YURT
MKRyan
