Old 12-06-2020, 11:24 AM   #21
I’d guess the door tolerance issue stems from the hinge. I don’t know what the Transit has for hinge adjustability. The E-series is easy. It might not even me a manufacturing issue. Slamming the door with something caught inside the hinge-side of the door can tweak things just enough to alter the door gap.
Old 12-06-2020, 03:39 PM   #22
bitburger's Avatar
>"How do you like the 4x4 Bitbuger? I will surely have him raise the shock mounts and the intercooler does seem very exposed. I have the Flatline Van co rack and ladder on my list, I like how easily a Fiamma can be mounted and that the top rails can be moved wherever."
I suspect that 95% of my usual driving could be successfully done in a ford focus, that said, I went to Baja this fall and needed 4wd on a regular basis or I'd still be down there digging myself out.
I wish there was a bit more clearance and I am already thankful for the bashplate. It's expensive and adds weight and complexity but it was a good decision for me.
Note that Quadvan also installs Aluminess stuff and is aware of door fit issues so you may want to raise the conversation with him if it's still outstanding then. In general, John didn't seem pleased with the Transit door hinges.
Note that while I expected 2 weeks for my conversion, it ended up being a bit longer. If you are on a time schedule, you may want to let them know so they are aware of it.
2008 SMB EB-52, Quadvan 4x4, 6.0 PSD SOLD
2017 Ford Transit T250 148WB mid-roof w/ Quadvan 4x4
bitburger is offline   Reply With Quote
Old 12-07-2020, 11:09 PM   #23
Thanks for the info. I am not in a hurry for the conversion and it may only be the second 2020 he’s done so I’m planning on being patient. Hopefully it won’t take more than 2 months. I’d like it for spring!
Ryan_A is offline   Reply With Quote
Old 05-18-2021, 08:09 AM   #24
Air compressor location
Originally Posted by Ryan_A View Post
That’s great you got 4x4 right away, right now there may be a year wait for Quigley so we decided to buy now so we have the van will have 4x4 by end of February. When do you think you’ll have your van? Is it a 2020? I heard they don’t even have their R&D done for them yet. Best of luck!
We decided to order our locker and air compressor now to make sure we have it for the build. Things are crazy now with Covid delays, so we’re stocking up, so to speak.
We are doing the same on our Transit T350. I am still deciding on where to mount the ARB single compressor. I have not been able to find room under the front hood (yet). Where did you end up mounting yours?
Thanks
kegsailing is offline   Reply With Quote
Tags
build thread, diy, ecoboost, quadvan, transit
