Go Back   Sportsmobile Forum > Sportsmobiles > Engines and Drivetrain
Click Here to Login
Old 06-20-2021, 03:23 PM   #1
Question adjustable track bar with heim or rod ends (at least 43-inches center-to-center)?
does anyone have a lead on a heavy-duty adjustable track bar with heims / rod ends for a 2006 SMB E350?
the existing track bar is non-adjustable and has bushings at each end.
we're going to lift the suspension 1-2 inches in the near future and will need a longer track bar that is adjustable.
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 06-20-2021, 05:48 PM   #2
Timberlines is adjustable with joints.
ScrapIron is offline   Reply With Quote
Old 06-20-2021, 09:02 PM   #3
REF
REF's Avatar
Send a message via MSN to REF
I had to replace the Quigley bar, couldn’t find new bushings for it so had a new one built recently at a shop that was able to get one fab’d up in Vegas with adjustable ends. Try to find a local shop that either does fab work or can have one made. Mine needed specific bends put in for clearance on the front diff, so not sure a generic one like the one referenced above will work.
Old 06-20-2021, 11:25 PM   #4
If you need one made try a serious off road Jeep shop.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 06-21-2021, 08:07 PM   #5
I bought spherical rod ends from speedwaymotors.com and a thick walled steel tube (1" OD x 1/4" wall I think) from Mcmaster.com and drilled and tapped threads in the tube for 5/8" rod end threads....or maybe they were 3/4" threads...can't remember.
https://www.speedwaymotors.com/Searc...m%20rod%20ends
I considered going larger on the tubing diameter but the one I took off was smaller and the max capacity in my lathe is 1"..........works great. I needed a longer/adjustable track bar with rod ends because I moved my front axle forward 1".
Old 07-02-2021, 05:22 PM   #6
found a solution
found a solution at WFOconcepts ... 1.25-inch OD DOM tubing that is cut-to-length and tapped with threads = https://www.wfoconcepts.com/pr/Custo...3163/4295/3707
add in some rod ends +jam nuts +misalignment spacers - https://www.wfoconcepts.com/cr/7-8-x...199/3260/19418
the new track bar should be here next week.
Chris
