Old 02-12-2024, 10:22 PM   #21
Pimpon's Avatar
Originally Posted by kbeefy View Post
I think the ECU is near the master cylinder on vans.
ok I will look
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
Pimpon is offline   Reply With Quote
Old 03-04-2024, 11:36 AM   #22
Pimpon's Avatar
I still haven't found where to plug the chip
Old 03-04-2024, 12:07 PM   #23
schluchtenflitzer's Avatar
it is pluged into the PCM. You have to open it to do this
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 03-04-2024, 11:03 PM   #24
Pimpon's Avatar
where is the PCM I no longer have the body it is painted I will look at the other black Ford
Old 03-04-2024, 11:58 PM   #25
1der's Avatar
On the firewall in the engine compartment to the left (inboard) and below the brake master cylinder is a large connector with many wires. The connector is secured by two 10mm bolts. This is the connector to the PCM.
i do not remember how the PCM comes out after that but it is very obvious.
Carefully follow the instructions for installing the Hydra onto the PCM circuit board. The contacts are usually coated in a plastic that needs to be very carefully scrapped to make sure there is good contact.
Old 03-05-2024, 01:10 AM   #26
PCM comes out to the inner side, first you have do unscrew the conector outside.
Old 03-05-2024, 10:16 PM   #27
Pimpon's Avatar
I haven't found anything, either with the translation I don't understand where it is or am I crazy, isn't there a tutorial?
Old 03-06-2024, 12:57 AM   #28
Old 03-17-2024, 03:48 AM   #29
Pimpon's Avatar
I would like to perhaps place the filter so have you done it or not....
https://www.amazon.com/dp/B0CMQCXG97...WxfdGhlbWF0aWM
Old 03-27-2024, 12:52 PM   #30
Pimpon's Avatar
Well I dismantled the box, the card and the original, you believe.
