Originally Posted by ScrapIron
That's what I would do. I have my manual in hand so I just use it. In fact, I hate buying a vehicle without it's manual and usually order a printed copy on day 1 of ownership. No quicker way to figure out where that damn fuse that just blew is IMO, Lol.
- As per the other thread right now on transmission fluid I would recommend Motorcraft transmission fluid.
- Brake fluid I just use a good synthetic. The biggest thing is to actually change it, which no one ever does. It makes a big difference hauling these heavy things to a stop coming down a mountain in August.
- Transfer case I use whatever the case specs, since no vans came as 4x4.
- Axles I let a professional do. I ask them what they'll use and double check it.
- Oil I use Motorcraft semi-synthetic but am not averse to Mobil1 or Castrol Syntec synthetics if they are cheaper.
- Coolant I do not remember but check spec and use it. Coolants, like transmission fluid, have gotten wonkey over the last few years. You can't just trust that the old green stuff is best anymore, however I do think it is safe to use in a pinch so long as you replace with spec soon.
