1998 Chevrolet G2500 van body. AC went out. had compressor replaced but there is currently no power to the compressor clutch, so the new compressor won’t engage.
My mechanic is blaming “customer wiring” I.e. the Starcool system for being unable to diagnose. I provided the Starcool Manual and wiring diagram, but so far no luck. It looks like from the diagram that the only interface to the engine compressor is right off a fuse block, past the “40 amp manual reset breaker” but there is no indication if the block and breaker are SMB installed or factory, and no Indication of where they are.
Anyone have any experience with this?
Sort of cross posted in the Lappliance” sun
https://www.sportsmobileforum.com/fo...tml#post322204
