Old 06-04-2020, 09:48 PM   #11
freeagent's Avatar
Originally Posted by KDB View Post
I ordered mine back in march i believe. Just got it a week or so ago. I'll make sure to update the thread once i give it some regular use.
I did the same and ordered back in March during the pre-order. I think I had pretty much forgotten I'd done so until it showed up this week. I've taken it all out to check it out but haven't used it yet. I'll also report back once I've had a chance to use it so that others that are thinking about ordering one can have some feedback.
At first glance though, I'm pretty impressed with what I got.
2005 E350 4x4 V10
freeagent is offline   Reply With Quote
Old 06-05-2020, 03:49 AM   #12
marret's Avatar
Looking forward to hearing how these water heaters work out. I'm going to install one on my new cargo trailer at some point and still pondering options.
Thanks.
Chris
Old 06-05-2020, 01:09 PM   #13
One thing that isn't being discussed is that straight propane won't burn well at altitude and you need a propane/butane type of mix. Having a tank filled in CO should get you a different mix than what you would get at lower altitude like sea level.
Old 06-05-2020, 01:39 PM   #14
jredone's Avatar
Wow I did not know that. Exactly why I came here for advice in the first place. Right on thanks !!!
jredone is offline   Reply With Quote
Old 06-09-2020, 07:09 PM   #15
jredone's Avatar
So I got my Triton all set up. Pretty unimpressed with the quality. Very cheaply made but it does what it’s suppose to for now. Can’t see it lasting more than a couple trips with regular use. I’m barely 300ft above sea level so the upcoming trip to Crested Butte will be the real judge. I’ll be trying what @eddyturn suggested about filling up in Colorado. Maybe I’ll do a little test burn with both the different propane mixes.
BF3A47EB-DDA1-4110-8FBA-3225CC734991.jpg   314F3C24-5E4D-40B1-A8BD-589DDDE3A880.jpg
Old 06-09-2020, 07:10 PM   #16
jredone's Avatar
Sorry they’re sideways, lol every time only on smb forum though
Old 06-09-2020, 11:27 PM   #17
Otter's Avatar
^^^^ If you just edit them in IPhone and alter the size even a tad, it’ll post right side up here.
Old 06-10-2020, 07:51 AM   #18
jredone's Avatar
Let’s see if the resize works
8850C92D-150D-459B-8942-42A3DC2ABC09.jpg   388AD123-8F5F-477F-AD9C-BE5B8A9A3DD7.jpg
Old 06-10-2020, 11:29 AM   #19
marret's Avatar
Yep, photos right side up. Thanks for the info. Look forward to hearing how it works.
Chris
Old 06-10-2020, 02:55 PM   #20
KDB
KDB's Avatar
I do a lot of backcountry hiking and haven't had any issues using cold weather blends for fuel. Isobutane seems to be the key ingredient in those and my stove has never let me down while in the high country. Eddyturn's tip about using a blend sourced from a high altitude location is a good one. Good chance it's a blend of some sort.
KDB is offline   Reply With Quote
