EDIT:
My analysis assumes that all currents return to B- of the house battery. If there is an alternator charging the house battery then that is the source and the charge currents return to the B- of the start battery. This analysis just helps to understand how the current will flow. The only currents being monitored are those into or out of B- (house battery negative terminal). So the Frame ground needs to attach at the P- bolt of the house battery shunt.
Originally Posted by CDACamper
@Posplayr Thank you for the info. I'll look into the grease and compare it to the dielectric grease I have.
My system is wired like the diagram you included. I am unclear if I should also ground the load side of the shunt (the side connected to the load negative) to the a chassis ground. It doesn't specify this in the diagram. I currently have this side of the shunt connected to the top of the wheel well.
I have tried to avoid running House power current returns through the frame. Sportmobile did so that is the way that it is designed. I presume they are using the frame to return alternator currents that charge the House battery bank.
Even though we think of the Frame as a "ground", the most negative point in the system with respect to the house battery is the negative pole of that house battery bank (B-). The battery monitor shunt P- is at a higher potential and following that is the negative busbar followed by the connection to the Frame Ground.
Frame Ground > P- Busbar > P- > B- (lowest house potential)
If you want to include the alternator charging currents in what the battery monitor senses, then you can either connect the Frame return lead to the P- bolt (the same as where you would branch off to your P- busbar. or to the busbar itself if it can handle the current.
The is nothing wrong and it is probably preferable to go to the same P- bolt (at the shunt) with the heavy ground /frame lead.
Glad you are an attentive reader and caught on to the grease. Yes, Dielectric is an insulator whereas the other is conductive.
