Old 09-03-2010, 10:09 AM   #1
Rapidz's Avatar
Sportsmobile 4WD maintenance
Do most Ford dealerships know how to work on Quigley 4WD?
Say, like for lubes and changing fluids?
We just got our SMB this summer. It's an 02 and in fantastic shape.
Thanks,
Rapidz
Rapidz is offline   Reply With Quote
Old 09-03-2010, 10:19 AM   #2
Roonie's Avatar
Re: Sportsmobile 4WD maintenance
Yes.
The engine is not changed from stock and the only thing that is would be some of the suspension components but on a quigley that is minimal. A sportsmobile 4x4 build however is a different story and uses a lot of custom parts in its conversion. Even then they still have factory rotors, calipers, and brake pads.
taken from the Quigley web site.....
Designed to be easily serviced by most Ford and Chevrolet/GMC dealers, the genius behind Quigley is its use of easily obtainable, original equipment suspension and drive train components from major automotive manufacturers.
The Quigley system is designed to retain 90% of factory components as possible (i.e. factory rotors, calipers and brake pads).
Old 09-03-2010, 10:27 AM   #3
Rapidz's Avatar
Thanks. We have some good specialized 4WD outlets in the Boise area, but to take it to Ford for minor 4WD maintenance would be a lot easier.
Old 09-04-2010, 06:14 AM   #4
Quigley's are readily accepted by the vast majority FORD dealerships as many of these Vans are actually ordered and delivered thru the dealerships and have been from Quigley's inception
The SportsMobile is an entirely different story , I have literally had to buy my way into a local dealership to have any warranty service performed . I was actually refused acceptance by four other dealerships in the nearly three years of new ownership . Thankfully I have not had any real issues with our SportsMobile converted Drive Train and a well maintained Van will eliminate worry of Drive Train issues . With regard to service from SportsMobile I would have to say that in my case it has been stellar .
Greggde
