Old 09-03-2013, 02:42 PM   #21
Re: Suggestions: stand alone inexpensive carport for 4x4 SMB
I'll probably go metal. I'm in the middle of adding a garage and a carport. Slightly more expensive though as far as carports go.
http://www.americansteelinc.com/
Old 09-03-2013, 10:10 PM   #22
I wanted a inexpensive temporary shelter and do a lot of wood working so I made my own. About $300.00 in materials, 4x4 pressure treated sill plates, joist hangers to mount trusses, 2x3 trusses, 2x4 purlins. Put I together in three evenings after work, it came apart in an hour and should go back up in an evening.
Orion is offline   Reply With Quote
Old 09-03-2013, 11:10 PM   #23
Old 09-03-2013, 11:16 PM   #24
Legit Orion.
Can you do it for me if I gave you $310?
Old 09-04-2013, 07:46 AM   #25
Originally Posted by Ocsmb
Legit Orion.
The truth about DIY if we had the pay for our own labor nothing would be affordable.
Old 09-04-2013, 05:33 PM   #26
larrie's Avatar
Maybe you could post the plans. That is a very nice piece of work.
Larrie
Old 09-05-2013, 10:25 PM   #27
loren85022's Avatar
I'll take DIY anyway. That a cool woodshop
Phoenix Arizona
2008 E-150 5.4L w/Quigley. Vangator II Wheelchair lift,
loren85022 is offline   Reply With Quote
Old 09-09-2013, 07:47 AM   #28
This is a JPG the sketch up file .SKP files are not allowed? The key to the build was using construction adhesive with the screws on the brackets and assembling the frames on top of each other with a 2x4 in the grove to maintain alignment. They sell a simple metal bracket for making this style of shed but I had the ability to make brackets so I did.
Old 09-09-2013, 04:00 PM   #29
.skp are only allowed in the .skp repository- post there and link
viewforum.php?f=43
It's under Homemade/Groundup as a subsection.
MCSporty
MSD
Vandemic
Charliesmom
