Belize - Did you put anything (like rubber or neoprene) between the aluminum backplate and the interior sheet metal?
Your discovery of the hacking and wiring is very consistent w what I and others have seen behind the finish work. the wiring at the driver side B pillar is a very, very vulnerable spot for chaffing / shorting out / fire. I recommend removing the B pillar cover and checking the wiring harness all the way to the stock roof level.
