One more thing.......V10's have a beefier/more desirable transmission than the V8's. The gas mileage between the two is similar, with the 5.4L getting a little bit better mileage.
This. You mention 2 passes at high elevation in the mountain west. The extra gear in the trans, plus the extra torque of the V10, make a huge difference at altitude. I've test driven 2 V8s, one stock gearing, one with 4.10s, and the end result was I bought a V10 both times. I'm also averse to just putzing along in the right lane, so if that's your speed - the V8 will do just fine.
I know this is a Ford centric forum, but it sounds like you might want to check out some of the Chevy options too. 2010 and up will have the 6 spd trans which is a real nice bonus, plus they tend to get a bit better mpg overall. Or if you go diesel, the 6.6L is more modern than the 7.3, and not as problematic as the 6.0. There is or was a nice lifted 2wd SMB build for sale around here for ~$65k IIRC.
Edit: here it is:
https://phoenix.craigslist.org/cph/r...653543564.html
