Originally Posted by Marcel Huijser
We use ss autobolt as extra locks on all doors. Thieves can still break a window, but even when they crawl in through the window, they still can't open any door (unless they discover a secret hidden override that allows you to unlock the bolts when inside the van). Installation costs were high though; if you can get it to people who have experience with installing the system it is best.
I'd highly recommend the latest iteration of The Auto Bolt products---I had the earlier versions that were light years behind what they're now offering. When one failed there was no known way to release them---huge problem as you might suspect.
I sought another type deadbolt lock system which allowed me to add a hidden manual defeat feature. Should one of the locking solenoids fail or even a dead battery I can access the areas protected by the deadbolts.
Deadbolt lock installation can be labor-intensive as alignment of the lock and strike is critical. Its completely a DIY project but its not a 1 or 2 hour job. Parts would cost the usual user about $300, hired-out labor costs greatly varying depending who you'd use and how involved integration into the van you want to go. I've done this three times now and it does get "easier" each time out but in all honesty my biggest challenge was the alignment issue---I'd like to think I have that solved to some degree by now.
I have mine triggered only by the aftermarket alarm---they don't engage unless or until I arm the system. Normal door lock/unlock function is retained so there's no loss of convenience. If using an aftermarket alarm it should be able to integrate the deadbolt operation into its operation---whoever installed the alarm would be the best source of help here.
My van is now 99.9999999% protected from unauthorized entry though the side and rear doors, the front doors still unprotected. That's not an issue because all my valuables are behind the front seats and separated from the rear with a partition of sorts. I'll be installing a Ravelco system soon which should address the issue of the entire van being stolen and parted out somewhere.
Anyway seriously consider the deadbolt locks regardless whose system you use. Here's an alternative to The Auto Bolt---these would be my second choice were I to do this again (and currently what I have installed):
https://www.a1electric.com/catalog/cat_dead.htm
HTH
