Old 06-19-2023, 05:23 PM   #1
What kind of bolt is this and how do I remove it?
Trying to remove the housing for my solar panel, but the bolt just keeps spinning. O_O
355542319_966428411146339_8465642692090574485_n.jpg   355415137_658692122326630_6712559523071771138_n.jpg
MordikaiX is offline   Reply With Quote
Old 06-19-2023, 05:41 PM   #2
bigriver's Avatar
If that's on an SMB top there will be a corresponding cap covering the head of the bolt on the ceiling inside. You'll need to figure out how to hold one while loosening the other.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 06-19-2023, 06:05 PM   #3
Thanks Joe, I'll check it out. any idea what that type of bolt and cap are called?
Old 06-19-2023, 06:26 PM   #4
bigriver's Avatar
It's a normal bolt but not sure what the washers and caps are called... someone hopefully will chime in and let us both know.
Joe
2003 EB30 - Sold
Old 06-19-2023, 06:49 PM   #5
Field Van calls them capping studs and cap plugs
Old 06-19-2023, 07:18 PM   #6
I don't see any bolts on the interior ceiling, anything like that must be under the ceiling panel and I'm not ripping that apart.
The panels are secured to the frame the same way the frame is bolted to the top, those spin also, and there isn't a way to get to the underside of the panel and hold the other side of a bolt, also impossible to see. Is there another way to remove them?
I found this post, but not sure how the nuts were removed.
http://www.sportsmobileforum.com/for...tion-4355.html
Old 06-19-2023, 07:29 PM   #7
Steve C's Avatar
Any chance you can take a picture of the interior ceiling where your bolts should come through the top? There should definitely be some covered bolt heads on the interior that you can easily access. Could also be incorporated into the bolts holding the grab handles to the inside of the ceiling (depending on where those brackets are located on the pop top).
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
Steve C is offline   Reply With Quote
Old 06-19-2023, 07:42 PM   #8
There are bolts at the grab handles, but that is a completelydifferent location than the bolts holding on the solar panel frame. You can see those 4 bolts at the back of the 2nd image.
Its just a white ceiling under the bolts from the solar panel.
348383409_236497132463114_1813417503298132814_n (1).jpg   348383198_3428904160666024_5106375287775257389_n.jpg
Old 06-19-2023, 09:00 PM   #9
If you are lucky these are outside of the pop-top, so lift the roof a little and see if you can find the bolt outside of the canvas.
Old 06-19-2023, 09:03 PM   #10
I believe the scale of things is fooling you. I think these bolts (on the underside) are on the outside of the canvas. Take a look.
Tan Hot Dog
Jsweezy
The YURT
MKRyan
