Old 03-15-2015, 11:05 AM   #21
Re: Tire and Wheel Gallery
Method nv wheel with 315 cooper st Maxx on 6" Ujoint lift. Haven't gotten to test them out yet- but it looks great.
ohpyramids is offline   Reply With Quote
Old 03-15-2015, 05:29 PM   #22
OK, I'll jump in here with my setup:
BGF T/A KO2 35x12.5x18 on AR708 chrome wheels
2014 Black Ford E-350 V10 QuadVan getting built in Spring
2010 Ford Raptor 6.2L
prally is offline   Reply With Quote
Old 03-15-2015, 07:03 PM   #23
ATX Mojave teflon 17x8 0 offset, 3300 lbs load rating
Nitto Terra Grappler 285/70-17 Load rating E
Van has 4" lift Dana 60 front axle, some rubbing on rear edge of front fender wells when turning and compressing the suspension, even after some trimming.
Old 03-15-2015, 09:48 PM   #24
RandallDee's Avatar
I found a set of 4 ATX Mojave teflon on Craigslist for $200 and picked them up for $180. They were straight and true but two of them had some light curb rash type damage. Some light file work, filler and sand paper smoothed them all out before I rattled canned them.
They're 16 x 8 with 285/75/16 Cooper S/T Maxx. The van has an Agile Off Road TTB Dana 50 set up. Overall lift from stock is about 2". I really like the lower stance and I'm pretty happy with the tires.
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
RandallDee is offline   Reply With Quote
Old 03-25-2015, 05:03 AM   #25
Wbp
I added these to my 2wd eb ledge 17x8 0 offset with toyo LT265/70R17 OPEN CNTRY A/T II E. Also added a 2" lift from action everything fit perfect no rubs.
Wbp is offline   Reply With Quote
Old 03-25-2015, 01:15 PM   #26
Sorry, mine is not 4x4 or a SMB but this might be useful just the same! 2wd with Camburg "Baja Performance" kit which measured right at 5 1/2" taller than stock.
Tires:
285/75/17 Nitto Trail Grappler
Actual measurement: 34.1" x 11.6"
Load range E 3195lbs @ 80psi
Wheels:
American Eagle "012"
17x9
4.75" backspacing / -5mm offset
load rating: 3420 lbs
I trimmed the backside of the front fender about 1" and have zero rubbing there at full compression regardless of where the wheels are pointed. I also spaced out the stock bumper 1/2" (using plate washers) and the tire can just graze the bumper if I bottom out with the wheels turned.
Old 03-26-2015, 12:45 PM   #27
Viejo's Avatar
Here's mine...
Tires: Hankook 315/75R16 MT - getting near time for replacement.
Wheels: You tell me - please. Broke one last summer and put a ugly junk yard wheel on the spare, need to replace it. It looks like what others here have labeled as Mojave.
When we went with the 315 tires, we had to trim back the wheel wells and part of the bumper skid plate.
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 03-26-2015, 01:25 PM   #28
16" American Racing/ATX Mojave Teflon coated
Old 03-26-2015, 03:36 PM   #29
Viejo's Avatar
Thanks...
2002 E350 7.3 PSD
Old 04-01-2015, 08:56 AM   #30
Tapatio's Avatar
Pro Comp Model #7089-6882
With BFG All Terrain T/A KO 285/75-16
Callsign KK6GIY
