OK, here is my plan.
Disclaimers
1. This is for my van, which has the K30 front brakes. If your van has F350 brakes or something else, I don't know, talk to Quigley, give 'em your VIN.
2. If you order these parts and they don't fit, it isn't my fault, I'm still waiting for them. And even if mine fit and yours don't, that's your look out because I know nothing about your van and part of me suspects no two Quigleys are alike.
I did the original research about 5 years ago at FordTrucks BB and this combination was a common recommendation for people towing. The brakes I had on my 99 E350 cargo were great for everyday driving and towing after I did this upgrade.
Rotors
Firstly, cryo slotted rotors from Stoptech. Slotted helps vent gas/dust and gives a little extra bite at the expense of some pad life. I had them on my prior E350 cargo van and they were great. Cryo treating can help prevent cracking from overheating. Whether you need this is up to you, I do a lot of towing, and there's a lot of heat build up and I think the rotors are really undersized for the load. Plus the rotors are a pain to source, machine and replace, so I'm ok with spending the extra money for some extra durability.
This isn't the cheapest vendor for non-cryo treated (see link from Jacko above) but for the cryo treatment the price is about the same (within $5/rotor).
Stoptech 126.66003CSL & 126.66003CSR
OR
Stoptech 126.66003SL & 126.66003SR
CSL = cryo slotted left
CSR = cryo slotted right
SL = slotted left
SR = slotted right
The cryo treating is a special order and takes longer. There isn't much stock around so if everyone buys rotors, Stoptech will have to make another batch.
http://store.zeckhausen.com/catalog/adv ... =126.66003
There was a lot of research to get from the rotor p/n on the Quigley drawing to this number but you can also get there if you use the Stoptech K30 link I posted above.
Machining
My rotors are being shipped directly to Quigley for machining to give clearance for the Ford ABS sensors. This was the quickest solution vs finding somewhere locally that would do it. $60/pr+shipping. Talk to Joyce or Tiger @ Quigley. Or talk to them to get the PDF drawing to get it done locally.
Pads
I had previously used Hawk LTS pads on my 99 cargo van and loved them. They aren't available in this application and with the weight difference between an SMB and a cargo van, probably justified using the next step up, SD pads.
Hawk Performance HB337P.791 SuperDuty Brake Pad
http://www.amazon.com/gp/product/B000CLRBRC
There are probably other places to buy the pads, Zeck is a dealer for Hawk too but I had already ordered my pads.
They match the D149 FMSI # on the Quigley drawing and also the K30 application if you look it up from that route.
