View Poll Results: What material do you use between the bracket and the van body?
1/16" butyl sheet 1 33.33%
1/8" butyl sheet 1 33.33%
1/4" butyl sheet 0 0%
something else 1 33.33%
whishful thoughts (nothing) 0 0%
Voters: 3. You may not vote on this poll
Old 09-07-2009, 05:03 PM   #1
Eli's awning bracket owners (current and future)
I've ordered a set of Eli's awning brackets, and I'm curious what, if anything, users have placed between the brackets and the van body.
Old 09-09-2009, 10:38 AM   #2
Re: Eli's awning bracket owners (current and future)
I don't think Butyl is the right material for the application, unless you're using it to cover old bracket holes. I think some kind of rubber pad that wouldn't expand, sqeeze out and melt would be better... even if you put 1/2" butyl in, when you're done it will probably be the same size as the 1/8" would.
Old 09-09-2009, 10:00 PM   #3
mjeffrey's Avatar
There must be different types of 'butyl.' The butyl rubber I used is similar to inner tube material - a very dense rubber, that flexes well but doesn't compress much at all.
mjeffrey is offline   Reply With Quote
Old 09-10-2009, 09:15 AM   #4
Ah, that would explain things- the butyl I have is closer to silly putty. It works great under washers, around holes, etc. but wouldn't make sense for this application.
Old 09-10-2009, 06:55 PM   #5
Great...so now how do I find out which one to buy?
Old 09-10-2009, 07:01 PM   #6
mjeffrey's Avatar
This is where I got mine, for some other project:
http://www.mcmaster.com/#butyl-rubber-sheets/=3ks818
Old 09-10-2009, 09:46 PM   #7
The material that I used on my Penthouse roof leak was Butyl Rubber Sealing Tape.
http://www.mcmaster.com/#butyl-rubber-tape/=3ku9ts
I believe that this is what Jage is referring to.
Same place different Butyl
