Old 09-15-2016, 06:28 PM   #11
vwteleman's Avatar
I'm actually only somewhat joking... you could get a box of these. Cheap (about 5¢ a piece) and effective.
Old 09-17-2016, 08:53 AM   #12
I have to laugh at some of the uses for the finger condoms.....I use them on the barrel of my muzzle loader in damp conditions. Nothing like having dinner in front of you with wet powder.
hogasm is offline   Reply With Quote
Old 12-09-2019, 12:37 AM   #13
Hydraulic line covers.
I use hydraulic line dust caps. Still have to replace my couplers every couple years but it keeps the mud out.
DaYeti is offline   Reply With Quote
Old 04-14-2023, 09:23 AM   #14
Originally Posted by JackTuppVan View Post
I have had the same problem .
You can eliminate the external female quick connector and replace it with a ball valve and male quick connector .
Open the valve before connecting the hose to purge any debris from the orifice.
Install two female quick connectors (one at each end) to the accessory air hose
that is stored inside out of the weather.
Revisiting this old thread since I'm soon to mount up a new OBA system.
Jack's idea above is the best I've figured out. I'm about to have Aluminess front and rear bumpers with storage ports (which aren't weatherproof but are at least not out in the open) and I might go that route.
I've also thought about rigging a single coupler up inside my fuel door hatch. There's a good bit of open room around the fuel fill on E-series vans.
I put a coupler out in the weather on my wife's Jeep and it works fine so far with a cane rubber tip but they are not at all UV stable and break down to bits in a few months if exposed to direct sunlight.
It kind of baffles me in the world of trendy, expensive offroad bits that someone hasn't thought up a bulletproof air line coupler for off road rigs.
Old 04-14-2023, 11:54 AM   #15
Originally Posted by Nrobert10 View Post
We use caps on standard air line quick connects all the time. If your looking so standard connection caps check granger I think they are item #20LJ96 catalog page 3124. You can also search propane hose quick disconnect caps they are pretty close to the same size also.
Haven't figured out how to post a link yet.
Current link to item 20LJ96
https://www.grainger.com/product/SNA...ue&tier=Tier+6
Old 04-14-2023, 12:17 PM   #16
aarcaris's Avatar
Here is one option that I was considering using once I get my OBA system figured out. Quick Connect Air Coupler Pacifier- NITTO Hi-Flow Couplers
They offer a few options along with some other OBA accessories that are pretty sweet!
Vandit - 2013 E250 Ground Up Build
- Full Custom DIY Interior Build
- DIY U-Joint Off Road 6" 4x4 Conversion
aarcaris is offline   Reply With Quote
Old 04-14-2023, 01:32 PM   #17
velo47's Avatar
These work for me
https://morrflate.com/shop/morrflate...orrflate-caps/
W3TAX
WRDZ686
2016 4wd 144" Sportsmobile Sprinter
2019 Chevy Colorado ZR2
2002 lifted & armored WRX wagon (sold)
velo47 is offline   Reply With Quote
Old 04-14-2023, 05:59 PM   #18
Wit's end also has a pacifier specifically for ARB couplers.....apparently they are a little non-standard...
https://absolute-wits-end.com/arb-fi...pler-pacifier/
Interesting...they are available in black Delrin, Brass or anodized aluminum.
Old 04-14-2023, 06:16 PM   #19
Twoxentrix's Avatar
If you're intent is to protect the fitting (Dust, debris, weather, etc.) you should consider the Sherman cap (pricey, but full protection):
https://www.rockyour4x4.com/?product=sherman-cap
EDIT:
Or...
https://www.northridge4x4.com/part/c...SABEgI0I_D_BwE
https://hosewarehouse.com/products/5...CABEgJfUPD_BwE
Old 04-14-2023, 07:19 PM   #20
I like that Sherman cap! A few have posted, and I was already aware, of the rubber/plastic type caps on a tether like your second two links. The problem I see with those is that water/mud/sand get into the back (spring loaded) part of the couplers are eventually ruin them. I like that the Sherman cap completely encapsulates it. Cool design.
