Old 05-09-2012, 11:14 PM   #21
Re: My build so far
I used the holes that are already in the door and put a 2" bolt and washer through it, then I ran a nut and washer on the outside of the door and used locktite to secure the nut/bolt. Because the inner and outer door is so deep I could use a wrench to hold the bolt in place. I took a piece of cardboard and pushed it over all four bolts and used it as a template to drill the holes in the back of the cabinet.
Once the holes were drilled I pushed the cabinet on the bolts and ran another set of washers/nuts and used locktite once again. Then I used a dremel and cut off the excess bolt.
Does that make sense? I can't promise it was the right way, and I haven't put it to use yet other than opening and shutting the door---and it seems to work fine.
Let me know if you have questions or want pics. I didn't take any as I was doing it, but can set up the same idea on the back doors if you want.
2horsegarage is offline   Reply With Quote
Old 12-02-2012, 11:32 AM   #22
Re: My build so far
nice work 2horse, i like your attention to detail, clean.
are you planning on converting to 4x?
I have been working on my e350 15passenger in attempt to do the same (we're campers and needed more space for dog, kids & their guests, etc. but want to get off the grid and hope to convert this spring w/quad van in portland. it's a heap of $, but want if for the shear pleasure of not having to always camp w/the masses. so, don't know if you've done any research...
i'm in the mostly learning phase since i started this process a little more than a month ago (with a little doing) and these posts really help.
i'll keep watching and learning as it looks like you will be adding all the stuff i'm researching: roof rack, bumpers, aux power, interior, etc.
thanks again,
dave
dwest is offline   Reply With Quote
Old 01-02-2013, 05:16 PM   #23
Re: My build so far
"Paint".... Couldn't really deal with the creepy van white. I had the whole thing sprayed with gun metal grey plasti-dip and the windows tinted.
Old 01-03-2013, 12:57 AM   #24
Pschitt's Avatar
Re: My build so far
Hey, it looks great like that ! Did you take much time to sand it before painting ?
Old 01-03-2013, 09:02 AM   #25
Re: My build so far
how much difference is there with the noise levels inside before and after?
"What'$ that funny noi$e?
Old 01-03-2013, 09:15 AM   #26
twogone's Avatar
Re: My build so far
Great color change!
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 01-03-2013, 03:55 PM   #27
Re: My build so far
I'm going to plasti-dip my van also. Just makes so much more sense than traditional paint. Great choice.
smshield is offline   Reply With Quote
Old 01-11-2013, 08:14 PM   #28
Re: My build so far
Incredible!
You have done a great job and have given me some great ideas. I love the tool box as a cabinet...definitely what I will be doing.
Never heard of Plasti-dip...awesome....
Thanks,
Steve.
Zack1965 is offline   Reply With Quote
Old 01-12-2013, 10:02 PM   #29
Re: My build so far
Thank you all. The plasti-dip is pretty simply all in all. I did not spray it, but it required almost no prep. It really is designed to just peal off...so no sanding. Just a good washing. The really cool part is if its scratched, just apply a dab of paint thinner and rub lightly until scratch is gone.
Old 01-13-2013, 07:36 AM   #30
UJOINT's Avatar
Re: My build so far
Looks great
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
