Old 03-06-2018, 08:04 PM   #21
Van is gettin some spa treatment for sure,great job! what’s the name of your rig “special ops”?
Zappo is offline   Reply With Quote
Old 03-06-2018, 08:58 PM   #22
Thank you!!
Panel structure was either birch ply, or MDF depending on the location. We kept the galley and the structural panel work behind the driver, but made new flush mount doors, the side and rear barn door panels were MDF.
Lighting:
Dimmer switch:
mfj20th is offline   Reply With Quote
Old 03-06-2018, 09:01 PM   #23
Hadn't thought of a specific name yet, but Special Ops is good!
Old 03-06-2018, 11:13 PM   #24
gcvt's Avatar
With that wrap...DigiVan.
Greg
New van: 2003 E250 EB10
Old 03-06-2018, 11:41 PM   #25
Originally Posted by mfj20th View Post
Thank you!!
Lighting:
Dimmer switch:
Thank you. Were the walls and doors 1/4"?
Hi, I’m Robert and I’m a vanaholic…
2003 Astro AWD
1999 E350 RB 7.3 cargo
2002 E150 RB 4.6 hightop van conversion
1999 E350 RB 5.4 Chateau
Old 03-07-2018, 06:39 AM   #26
We used 1/2" MDF, and had to do some bonding of multiple panels to then remove material to get the bends. For the 45 degree routing around the handles, etc--we bonded two panels for that section only to cut down on weight. Most of the existing Traverse structure was 1/2" and we matched that when we used the birch ply on structure. We removed the back of the vans wood structure (supporting bed) and fab'd metal/welded supports, which gave more room over two Frontrunnner sliding pullouts.
Old 03-16-2018, 09:52 PM   #27
Almost done withe the complete interior build, and am happy with the under rear seat storage part. My design/fabrication partner came up with a great way to use the new found space. We relocated the batteries to the former spare tire space, as well a removed the water tank. We added the Front Runner pull outs to the rear and created a space for a 8.5' collapsible ladder--for roof access/board racking and an aluminum floor jack with a Weldtec skid plate/mounting bracket. Used maglite clips to hold the jack handle and the handle is held in place by earth magnets. Color is a little off in this photo--color is grey, not tan. Front of panel has netting to hold odds/ends
Old 03-20-2018, 08:54 AM   #28
Switches on switches and comms
Some updated interior work just finished. Thanks to the help on this board, we've added the Bogart Eng. Trimetric monitor set up to manage/track solar and usage...that wouldnt have been possible without the great schematics and discussion here. Thank you!
Old 03-20-2018, 03:53 PM   #29
Twoxentrix's Avatar
You're really going-to-town on this Van - Great stuff - inspiring!
Old 03-20-2018, 05:51 PM   #30
Thank you...It's a fun project for sure. Learned heaps from the good people here.
