Rear spacers that convert 8 x 6.5" to 8 x 170mm are readily available.
If you are planning on putting Bushwhacker flares on the van you'll very likely need rear spacers/adapters. If you go for the F-series FF rear axle I think you can spec one a little wider to eliminate the need for spacers; the guy you want to answer that is Carringb.....or a few others around here.
If you go from 3.73 to 4.56 gearing in a D60 you'll need a different carrier too. I think anything lower than 4.10's requires a different carrier than a 3.73.
