Old 03-29-2020, 12:08 PM   #11
Originally Posted by Farmbro View Post
Thanks all, now that it stopped raining I have verified it is a semi-float unfortunately and so further thought required. Will investigate the Sterling axles and the full float Dana assembly which I may be able to pull from a wrecker locally to minimize the bill.
Presumably a full float from an ‘09 forward f350 should be a reasonably clean swap?
You will need a 2011 or newer F250 axle because of RSC. I don't think the F350 got RSC until 2014. Basically, make sure the new axle has outboard speed sensors and 2 brake hoses coming off the axle, rather than been teed into a single hose.
Old 03-29-2020, 02:44 PM   #12
Don't the 2013 and newer Sterlings have bigger brakes then the previous years?
Old 03-29-2020, 06:16 PM   #13
Yes. That's another good reason to go newer.
Old 03-30-2020, 02:50 PM   #14
So I found a full float Dana 70 out of a 2014 e350 with 4:10’s in it albeit not sure open or LSD but has the disc brakes already. Presumably a pretty straight upgrade albeit I suspect hub size will be bigger than 125 which is my current wheel set up? Width and spring perches etc should all line up?
Farmbro is offline   Reply With Quote
Old 03-30-2020, 03:02 PM   #15
This will be a direct drop-in. Hub diameter is the same. But beware it's 5" wider, and you'll still need the wheel adapters to match your front bolt pattern. Also... make sure it's not from a dually. Sometimes the wrecking yards aren't so good with their descriptions or cataloging.
Old 03-30-2020, 03:27 PM   #16
Comes from a single they verified that and they gave me the VIN so will double check with the dealer. Trying to understand the RSC issues as it seems to have been a cut away vehicle originally and may or may not have been configured.
Width was one of those things I was working on next - 5 inches is huge - seems like zero offset rims needed instead of the negative 12 I have currently to pull the width back otherwise am well beyond my bushwhackers
Old 03-30-2020, 07:16 PM   #17
Based upon what I see here on the brake line junction this seems to be a 3 and not 4 circuit ABS so no RSC compatibility for my application - am I looking at it correctly?
Old 03-30-2020, 08:21 PM   #18
Can you get any more pics? The important piece to verify is that is has outboard wheel speed sensors, which will be poking through the brake backing plates.
Old 03-30-2020, 10:13 PM   #19
It sure I see much here beyond emergency brakes
919C5616-E7DA-43D0-896B-0C0702A1CF6C.jpg   A39E560F-29DD-423B-B945-633D0E1E97BB.jpg
Old 03-31-2020, 08:36 AM   #20
Unfortunately whoever took those pics is smart-phone challenged.... it's too blurry to see any detail. All I can suggest at this point, is to verify the outboard speed sensors in person.
