Originally Posted by Twoxentrix
That's a tempting offer...I certainly wouldn't hesitate hiring you!
Thanks for saying that. It means a lot.
Originally Posted by cvman33
I may have missed it, but what was your fix for fitting the 37's?
Fix was just to go higher and slide the axle slightly farther ahead. We ended up using 6" lift coil springs designed for a 2wd truck to net the desired height. As I've said in previous posts the steering geometry is pretty step, however the downward travel is limited by the springs/shocks and stops before any of the ball joints are completely out of travel. We've discussed adding a high steer kit to improve the geometry but we are waiting to see if the owner actually uses and keeps this van (has a history of building vehicles and never actually using them).
Originally Posted by Abitibi
Great job Pucry!
I'm also in the middle of a self 4x4 conversion and know the pain and satisfaction involved.
As for vehicle choice, I've had a 01 E350 7.3. Very reliable but very loud compared to the 6.0 that I currently have. The 6.0 also have more power!
The 7.3 had a larger exhaust (and a bunch more mods before I sold it) so that may be part of the loudness but I recall it being loud in stock form.
The 6.0 on the vans, especially post 2006 (where they addressed some issues) seem very reliable. I bought mine at 445,000km, it runs awesome, tons of power and did I mentioned soooo quiet!
Regardless, go for it!
Cheers,
David from BC
Attachment 35323
Thanks David. I have 94 F250 diesel with the pre-powerstroke 7.3 turbo IDI engine. I love the truck and body style but whenever I ride in a newer diesel I can't believe how quite they are. In a van body where the engine is so close to the occupants I can imagine this would be even more pronounced. Definitely a reason to go with a 6.0l van over the 7.3. I've been digging into some of the issues of the 6.0l everything seems doable with some effort. Head studs are obviously the most involved but since the van is detuned and I have no plans to increase the hosepower I don't see them being necessary. It's nice to hear someone is getting good mileage out of a 6.0l and not hating every minute of it.
Originally Posted by JWA
Still ^^ one of my all time favorite DIY conversions here---impressive in scope, design and execution IMHO!
Thanks for the kind words. Really had a blast with this build and can't wait to do it again. I learned so much and would like to make a few slight tweaks to version 2.0.
Version 2.0 might happen soon too!!! I looked at a van on Monday that was good, low km, 6.0 L, mint interior with 4 captain chairs and 1 bench. The only thing I'm hung up on is it was very rusty for only have 90,000kms. The van in this build thread had 160kms on it and was way cleaner in that respect. I took for granted that it was normal and so when I knew I was looking at a van with significantly less kms on it I was expecting it to be even cleaner. That being said if I'm too picky I'll never get one so I might just have to move ahead and plan to replace the rockers and part of the rear quarter panels.
Originally Posted by b. rock
Nice work with the aftermarket arms. I was also looking into those for a radius arm conversion for the extra adjustability and clearance. However after dabbling with the van off road I'm not sure that'll really be necessary as the size and weight of the van will likely be the limiting factors first (at least for a big diesel EB. A gas RB can get away with a bit more). Nice packaging and especially nice work on the fuel tank.
Thanks b. rock. Honestly we only went with the aftermarket arms for looks. I just really hate visually seeing the factory radius arms hanging way down below the frame on lifted trucks and vans. These arms have a fair a mount of taper built into them and I really don't know if they could be used on a van with lower ride height. I tried to tuck the mounting holes close to the frame even with that and our tall ride height we are only in the middle of the adjustment range. I'd worry if we were any lower or had frame mounts designed for factory arms that we'd run out of travel to have the caster dialed in correctly.
The fuel tank was one of the most challenging parts and one that I'd like to try version 2.0 of. Functionally it's great, install is tight but good but from a fabrication stand point I'd like to try again.
