Originally Posted by amamdani
thank you MG.
even though i don't require it, can i still use the ERA to compensate for regearing and wheel size, yes? also for the lo gear speedo correction, yes?
thank you.
This may just be for the 4r100 -- but...
I haven't seen people needing an abbott for lo-gear speedo correction -- and even if you did -- you'd need it to be a separate one than the one you use for re-gearing and wheel size... since your speedometer sensor is using transmission output shaft revolutions to determine your wheel speed (IIRC) -- this could all be different for the 4R75
Thus -- when you go into 4LO you're getting 2.72:1 gear reduction -- so you're getting 2.72x more output shaft revs per tire revolution -- so you'd need two Abbots -- and a relay to trigger which one is active -- one for when you're in 2LO or 4HI with 1:1 gears in this transfer case and one for when you're @ 4LO with 2.72:1 gear reduction.
This was an issue with my Astro -- where you had to ground a pin @ the PCM to tell the computer it was in 4LO so it could do this math for you -- the F-series (where our axles come from) doesn't have this feature and the speedo signal is sent from the rear pinion on the older trucks. I'm not sure how it is sent on the newer trucks.
That being said -- the even if the speedo is off -- I think this shift points for the transmission should remain the same -- which is the more important part -- but I haven't dug into this very deeply.
The Abbott unit is great - but I'm going with this unit on eBay which is much less expensive and looks incredibly well-built -- I even spoke with the guy on the phone and he knows his stuff.
https://www.ebay.com/itm/UNIVERSAL-S...P/143554785386
You can go your own way there -- and mine isn't quite installed yet -- but the cost savings is significant for a very simple device.
Mind sharing a link to the u-joint thread where this is discussed? It's always had me curious and I haven't really seen it addressed..
