Anyone with the 5.4... Can i get a measurement from the front strap to the tcase? I will be shortening my tank soon but probably before the tranny shop can get me in. Want to take as little off as possible.
Which transmission do you have? I think 5.4 + 4r70 should not need tank shortened.
Got it. So you didn't need to shorten your tank? Was a while ago but i though MG said I'd need to shorten.... Fantastic if I don't need to. How much space do you have between the tank and the tcase?
I put in a ujoint tank based on some bad advice. So I can’t measure for you. But there is a mile between my t-case and the tank. I’m pretty seriously thinking about putting my stock tank back in.
Anyone in CA how did you deal with the cats and smog. I have 4 cats and the driverside needs to swap to pass to clear the tcase and front driveshaft i believe.
Hey guys and girls, I am finally getting ready to install the MG kit on a 2019 E350 turtle van. I have been collecting parts for two years now, and I think I have almost everything. I have read through this entire post and all the directions several times, but I cannot find directions on installing the coil spring mounts to the frame. Will somebody post pictures of them on the frame please.
