From the Sportsmobile website. SMB west did all the 4x4 conversions, but SMB still has this info on their website.
https://sportsmobile.com/sportsmobile-4x4/
SPORTSMOBILE’S 4×4 SYSTEM
The Sportsmobile 4×4 Vehicle is for the most discerning of off-road enthusiasts. Only the best heavy-duty components are used to provide the maximum off-road performance while maintaining exceptional on-road comfort.
This combined with over five decades of experience designing and manufacturing van campers makes the Sportsmobile 4×4 a truly unique product.
Ford discontinued the E-Series Van with model year 2014.
The only way to get the Sportsmobile 4×4 build is via the Sportsmobile Classic.
SPORTSMOBILE 4×4 CONVERSION INCLUDES
Advance Adapter Atlas II All Gear Driven Transfer Case
Dynatrac Pro-Roc 60 Front Axle
Dana 60 Rear Axle
Fox 2.0 Performance Series Shocks
High Knuckle Front End for Extra Tie Rod Clearance
Extra Heavy Duty Steering Arm
True horizontal drag link Spicer 1350 one-ton rated driveline components
Your choice of open, limited slip, or locking differentials
Partial military wrap springs designed specifically for a Sportsmobile Conversion
Reverse Shackle leaf spring design
Front sway bar with quick disconnect system and custom shocks
Front End Upgrades including new casting, larger knuckles and hubs
F550 rotors and beefed-up the calipers
GVWR 10,050 lbs
