Originally Posted by unreng
posplayr has the same idea...
I just have to cringe when people use double-sided tape and claim " I have not had any problems and been holding for 2 years"
Any body with any familiarity with residential solar panel-loading calculations knows that "uplift" is the biggest load. Depending upon what your local area and code require you could be looking at requiring hold-down strength to sustain 120-160 mph winds.
In a very benign example, say you are driving 70 mph and you have a "micro burst" of another 70 mph. So you are going from 70 mph to 70+70=140 mph.
The wind speed is now doubled and the power is now 8X. Now you could argue that it is only pressure-related which is only a 4X increase in force over the 70 mph forces.
Add on a rack-mounted solar that is spaced with plenty of room to allow wind underneath it and you have a very high potential hazard.
I attached pictures of my mounts that are using threadserts in the roof, but I was able to use different rights of the ABS to account for the curvature of the roof along with use the cavities to ensure a water-tight seal using the 3M sealer.
These are standard Renogy Z mounts. Notice how low they would be without my spacers t account for roof curvature.
My roof is now coated with an elastomeric coating which is very common in AZ so the combination of while 3M sealer and elastomeric just kind of blen in.
The ABS is nice t have on my metal roof, but on fiberglass, it is well-advised to avoid stress risers that can just cut the fiberglass. You might even consider rounding the edges of the ABS that go directly against the FB.
I can't actually remember right now because it is so long ago, but I bought a new Toyota pickup and a Snugtop rear cover back in 1987. I mounted board racks and I was real leery of drilling holes into what seemed like a semi-hollow shell. I may or may not have added an extra layer of fiber glass to the inside. i know I would have put something to cushion both outside (rack mount) and inside (oversized plate). You don't want metal right against the fiberglass.
