Originally Posted by DaneCorry
What transmission are you running / engine?
2013 6.7L out of a salvaged Ram 2500 and 2008 Allison 1000 6speed out of a medium duty truck.
I made my own bell housing adapter. Accelerator pedal is a combination of the stock RAM pedal and the Eseries pedal (the internals of the Ram pedal fit inside the housing of the Eseries pedal since they're made by the same manufacturer). Harness is custom made in-house. Engine and trans are directly connected and communicate via J1939 without any additional CAN "gateway" hardware.
The common misconception of the SAE bellhousing on the trans is that it is "too big" and "won't fit". The bellhousing itself isn't really that big but it is a very strong, thick casting compared to the GM housing. Where most people get messed up is that it's the industrial Cummins rear bellhousing that's ginormous and doesn't fit anything but medium duty trucks.
I liked the SAE (trans) bellhousing because I didn't have to move/change the original starter, the bellhousing ring was simple to design and make, the torque converter adapter ring was easy to design and make and I could use a commonly available torque converter and stock RAM flexplate (or in my case, an upgraded billet flexplate)
I have my drivetrain mounted as low and far back as I could get it and it is super easy to work on. I have plenty of access to everything...a lot easier to work on than any 6.0 or 7.3 van I've had in the shop. No additional body lift needed.
I've got to be honest, I'm not a fan of CAConversions. I talked to them at a show several years back and told them what I was doing and they laughed and said I'd never get anywhere with my setup unless I purchased their hardware. What they didn't know is that I already had the engine ECM and trans TCM communicating on the bench without their $1500 hardware (that's what it was at the time) and I'd figured out a way to get the 4th gen Cummins controller to work in a standalone application without any of the Chrysler add-on modules (BCM, SKIM, TIPM, etc...). My questions were about their bellhousing adapter and torque converter recommendations but instead I got an earful about how crazy I was for thinking I could get my rig running without their help. Rather than listening to what I was saying, two different people in their booth (I believe a father and son) talked down to me like I was an idiot. News flash...I'm not.
If you have more questions about my build, please follow up in that thread.
