05-01-2024, 05:46 AM
#131
Originally Posted by Twoxentrix
Vincent did you receive both boxes today???
One tracking number shows it was delivered today, but the other tracking number states:
Latest Update
Your item is being held in Customs at 8:45 am on April 26, 2024 in WISSOUS B COLIS, FRANCE.
I just sent you an email I received 1 parcel
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
05-01-2024, 06:19 AM
#132
Hi Vincent,
As you clean the turbo, did take the opportunity to open it on the exhaust side to clean the small parts of the variable geometry? They tend to get blocked by soot and calamine and it's good to clean those every 40-50,000 miles.
05-01-2024, 09:57 AM
#133
Originally Posted by Pschitt
Hi Vincent,
No, I cleaned it with a green ball, the translation must not be very good
the reassembly is done slowly fortunately I have the other engine to see a little
05-03-2024, 11:31 PM
#134
Vincent what were you doing here? Did you completely fill the channels in the front of the roof before painting?
05-04-2024, 10:44 AM
#135
Yes I filled it so as not to have any infiltration under the joint while rolling
05-04-2024, 03:05 PM
#136
That makes sense. Is it just aluminum rolled over on the edges and stuck down with the same seam sealer you used for the gutters? It looks great!
05-06-2024, 01:58 AM
#137
I folded a 1 mm stainless steel sheet and glued it with the same Sika glue.
05-06-2024, 10:52 AM
#138
Great, thank you!
05-07-2024, 12:24 AM
#139
Hi Vincent,
he has a 7.3 without variable geometry turbo. one of the parts you get less power from but also less problems
www.Dieda-unterwegs.net
05-10-2024, 06:35 AM
#140
which pliers model to choose? I already have foxes
