Old 08-31-2009, 06:07 PM   #1
Solar Shower build
Test project
Meant to mount left and right on aluminess roof rack
(but with 10 foot pipe)
Built with local parts, Lowes,Fergusons and Harbor Freight tools
Once i had all the parts and tools, it went together in 30 min
Only one leak, the upper galvanized pipe needed teflon tape
Vetoed the rack mount, i dont want 120 pounds up on my rack
Tools available if you want to build your own, you pay shipping
and the cost of a 12 pack
More photos in my gallery
bw out
Old 09-06-2009, 11:54 AM   #2
Send a message via MSN to SuperSuz
Re: Solar Shower build
any more pics mounted and in use (I mean the non neked kind )
More pics is better than more cowbell, most of the time. Thank you, Suz
Proud member of the Oakland Motorcycle Club
Weekends were made for adventures. Weekdays were made for chores and getting ready for the weekend.
SuperSuz is offline   Reply With Quote
Old 09-06-2009, 01:01 PM   #3
Note to builders, I used the "lightweight" not for pressure 4 inch pipe (Cellotex?-at home depot). Not the true schedule 40 stuff. It has bent/sagged in the 100 F. heat even when empty (no weight). Like a limp noodle handing over 3 Thule load bars.
Will have to be redone completely.
Tom
Tom
Austin, Texas
1995 SMB E250
bluedog225 is offline   Reply With Quote
Old 09-06-2009, 02:09 PM   #4
Is the top fitting to pressurize the system?
Did you consider installing the air line fitting into the end cap? It seems that it would be much easier.
Old 09-06-2009, 02:12 PM   #5
I thought the top fitting would be for filling.
I can see not wanting to drive around with extra water weight up top, but if you're parked you could fill it when you stop, go hike or whatever throughout the day and have hot showers in the evening. Kind of like a hard mount solar shower.
Old 09-06-2009, 03:30 PM   #6
They work pretty well non pressurized. Just gravity fed. One less thing to mess with.
Tom
Austin, Texas
1995 SMB E250
Sporty Spice
Tapatio
Rosy
Isever
