Old 10-26-2017, 10:29 PM   #2491
Gooseberry's Avatar
I did have a issue with the deflate cap not sealing on my test run so when you get it fill it with air and hold a cup with water to check both plugs are sealing. I just reset the cap and all was good
Sent from my iPad using Tapatalk
Old 10-28-2017, 09:44 PM   #2492
Today I took my scrap in and they had a pair of wheels off an f-250. One even had a good tire on it so I replaced my very rusted spare. Between the spare and the shackles I think I should start looking for more rusted out parts to replace before they fail. My factory installed tow plug is toast too from corrosion.
skoronesa is offline   Reply With Quote
Old 10-28-2017, 10:07 PM   #2493
Was your shackel failure due to corrosion?
Old 10-29-2017, 06:11 AM   #2494
Yes it was. the lucky part is that I had very little in the back of my van. If you start with an empty service van, just add 3 seats on a rack, a standard carry tool box with some winch stuff, and like a couple milk crates with oil/roadside stuff. It could have been much worse if I had my scrap in there like I was planning. I was on a pretty flat road only doing 30. I am sure it would have punched through the floor if I had hit a bump when it broke. It just tore right in two. Luckily I was close to home as well.
Old 10-29-2017, 06:15 AM   #2495
accrete's Avatar
Thumbs up
Originally Posted by Gooseberry View Post
...had Klymit gear...
https://www.klymit.com/double-v.html...
As a heads up to any Costco Members out there Klymit has been part of the road-show circuit. They were at my local Costco a couple weeks ago. The prices were a tad lower than their website prices. Looks like nice gear. I may pick up their insulated hammock pad for next season (they only had the non insulated one at the roadshow).
Thom
Greetings from the Sunny Southwest, USA
2017 RAM Promaster Conversion. SOLD: 2010 Chevy Express AWD
Van Build Thread @ SMBForums
accrete is offline   Reply With Quote
Old 10-30-2017, 02:40 PM   #2496
geoffff's Avatar
Originally Posted by geoffff View Post
Awesome idea, thanks! I have a 2" memory foam pad I fold up under the middle (hanging) section of the penthouse bed, but even that isn't enough extra padding for me. And there's no room up there to store more padding up there if the roof is going to close properly.
That inflatable sounds like a great idea. I might use it in addition to my memory foam.
-- Geoff
I ordered one of those Klymit inflatable pads, and it arrived today. The inflate-it-with-the-storage-bag process is a joke, though. Might as well blow it up directly with my mouth. Instead I'll order a $10 batter pump like this one to inflate/deflate: https://www.amazon.com/Intex-Quick-F.../dp/B004HC5Y4Y
2004 Ford, SMB 4x4, RB-50
Old 10-30-2017, 05:50 PM   #2497
Twoxentrix's Avatar
Agree completely the Storage Bag inflation process isn't effective.
Received my Klymit inflatable 2 days ago and had to try it out so I gave it the ultimate test last night - blew it up and slept on one of our wood floors. Slept through the night with no issue. Really are very comfortable. Convinced it will only enhance my comfort atop the mattress in the Van. Just as pleased with how small they are when deflated & rolled up.
Old 10-30-2017, 06:25 PM   #2498
rallypanam's Avatar
Try the Nemo brand inflatable ones. The pump is built into the mattress, inflates in 30 seconds using your foot to pump it up. Deflates in seconds when you open the big valve.
Have had mine about a year for motorcycling, it's awesome.
Old 10-30-2017, 10:46 PM   #2499
Gooseberry's Avatar
What did you do to your SMB today?
Ok wait I can have my klymit inflated in a couple minutes with the bag? Are you doing what I did and used the deflate plug to fill it?
Not saying it’s perfect but just have the bag flat with the bed and role up the opening. I do pull the bag open before I role it.
Hmm I do have a co2 tank within easy reach.
Old 11-14-2017, 01:24 PM   #2500
I got my floor in, and a bit more.
Finally got to spend some time getting the floor down so I can install the vinyl and start building. It was more work than I thought getting all that old flooring out and cleaning the thing up.
I guess almost 20 years of dust will do that. I made a video that has a lot of it.
I got the flooring all pulled out, used the old mat as a template to cut the 1/2 OSB for the floor sheeting. I put 1/2 in OSB strips in the low points of the floor and then reflectix in the high spots. I glued the strips down to the body and put a few screws in them, and then taped all the joints with foil tape and installed the sheeting with screws about every 6 inches into the strips.
I also got the FatMat installed on the roof panels to keep the noise and vibrations down after I pulled the headliner out.
I also have it all listed in my build thread, here in the forum.
Here is a list of all the parts I have used so far:
Reflectix BP24050 24-Inch-by-50-Foot
(This is probably enough for my whole van due to the windows on the sides. If you have a full size cargo van and want to do all the walls as a vapor barrier and insulation you will probably need 2 of them)
3M Foil Tape 3381 Silver, 1.88 in x 50 yd 2.7 mil http://amzn.to/2yAADLb
This works good to seal the edges of the Reflectix
Loctite Power Grab All Purpose Adhesive 9 Fluid Ounce Cartridge
I prefer this unless it is below 50 degrees or the surfaces are possibly damp if so I use:
Loctite Power Grab Ultimate Adhesive 9 Fluid Ounce Cartridge
Very similar to the one above but works well in colder conditions.
Loctite Polyseal 10 Oz White 2 In 1 Seal & Bond All Purpose Caulk
This is another great thing to have I use it for sealing gaps it skins over rather quickly
DAP 59184 QT Ready to Use Flexible Floor Leveler
Fills small gaps or inconsistencies in your subfloor, flexible so it won't crack with movement
3/4-Inch Modified Truss Lath Self Piercing Screw, 100-Pack
I used 2 packs between the strips and the sheeting on top of the slats.
FatMat Self-Adhesive Sound Deadener Bulk Pack w/ Install Kit
If you have a cargo van this is probably the amount you need I will have some left over
20171109_153026.jpg   20171111_165239.jpg   20171111_173354.jpg   20171112_160833.jpg   20171112_165418.jpg
"The problem with common sense is, its not that common." Mark Twain
1999 F-250SD XCab 4x4 5.4 170k
1998 E-350 LWB (Being converted now)
www.DirkMitchell.com
Dirk Mitchell is offline   Reply With Quote
