Old 03-03-2020, 08:54 PM   #2941
Glen's Avatar
Found it a girlfriend... It was love at first sight
Friends Don't Let Friends Do Stupid Things Alone
Glen is offline   Reply With Quote
Old 03-04-2020, 11:08 AM   #2942
wanderers's Avatar
Cute couple.
wanderers is offline   Reply With Quote
Old 03-04-2020, 09:33 PM   #2943
Spent 15 minutes swapping a salvage yard 2008 barn door wire harness and speaker into my 2006 door. Spent the next hour finding out that the 2008 harness is wired completely different and re-pinning the connectors in the B-pillar.
2 connectors in the B-pillar for the door and every single wire had switch positions with 4 wires changing from one connector to another.
2006 Ford E-350 6.0
Czar308 is offline   Reply With Quote
Old 03-06-2020, 11:53 AM   #2944
gahamby's Avatar
I just de-winterized the water system. The Beckson plate made it much easier.
Now getting ready for the first outing of the season.
'07 GMC 2500 6.0
Old 03-07-2020, 06:08 AM   #2945
BrianW's Avatar
I bought my SMB a friend! 2011 E250 EB full SMB (2WD) I'll have two for a bit until I get my old one prepped for sale :-0
Old 03-07-2020, 06:27 AM   #2946
Congrats on the purchase Brain.
Old 03-12-2020, 11:08 PM   #2947
installed some 1/8" uhmw plastic on the penthouse bed rails
and some Mac's aluminum versa track on the underside
and then created some custom conduit braces to support the penthouse rails near the mid-point
our rails were very "flexible" when being used and the rail had a slight smile shape (low point in the middle)...~1/2" drop with no weight on it. now there is very little flex and ~1/8" drop.
if needed, these are easily removed by undoing the wing nuts.
Each end can support a lot more than two people sleeping up top.
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 03-13-2020, 11:18 AM   #2948
Originally Posted by Mikerson View Post
It was 24 degrees out, but I got my driver’s side grab handle finished up.
Nice!! This is something I'm looking to do here soon. Did you just use an extra PS grab handle, cut holes in the A-pillar trim, and use rivnuts or something in the A-pillar?
Sigg is offline   Reply With Quote
Old 03-13-2020, 07:51 PM   #2949
Mikerson's Avatar
Thats exactly right. You’ll need the passenger side bracket too. It goes upside down compared to the way it sits on the pass. side. It sits a little lower too. It’s necessary because of where the spring clip that holds the trim piece on is. I don’t see being lower as a bad thing either. Since it keeps the handle from blocking your forward vision. I used a spade bit and a dremel to shape the trim. You have to notch out the ribs on the back side of the trim a little. The factory nuts are m6.
9E1513EC-C6B5-4C48-B8E9-258C72D18B0A.jpg   50EB119A-0E39-479B-B1CC-636CFB4A7328.jpg   A2B2DC9D-FD45-4AE0-9BFC-529591876F48.jpg
Mikerson is offline   Reply With Quote
Old 03-14-2020, 10:04 PM   #2950
Thanks! This helps a lot! I actually went to the JY today and grabbed a PS handle and bracket. It may sit for a bit, as I'm trying to finish up the floor and custom seating first, but hopefully soon. I've been anxious to try out my new rivnut gun!
