Originally Posted by werdstrave
Can anyone confirm that JWA's post on 1/18/21 is valid? I looked at my driver's rear fender and didn't see any existing wiring/clip that resembled those pictures. Just got back from the Ford dealer and had them enable VSC and nothing happened. Of course I replaced the clock spring and steering wheel before doing this.
So either I need vehicle specific buttons (my wheel was from a 2010 F) or I don't have the wiring to make this happen...
My post is indeed STILL VALID and even the march of time will not change it--take that to the bank!
HOWEVER beginning in 2005 with the E-Series VSC was entirely within the PCM so the physical wiring of 2004 and earlier will not be present.
Also you can NOT mix the F-Series electrical bits with the E-Series especially for systems like VSC. If you used F-Series control switches that's the problem.
I've said it numerous times before just because something physically fits does not mean it will function as expected. Yet time and time again we get these same questions---gets to be a bit frustrating but I'm anal so disregard as you will!
