Old 01-26-2023, 07:50 AM   #1
BrianW's Avatar
Adding external temp display? OEM?
I'd like to add an external ambient temperature display to my 2011 E250. I spent some time searching the web and didn't really come up with anything. I seem to recall someone mention that there was an OEM option in the Ford E-vans for a outside temp display, but I can't find any more info on it.
Yes, I know I can just buy an aftermarket stand-alone unit, but I've gone that route before and have found them problematic and not very accurate.
Has anyone here successfully done this? Thanks!
Old 01-26-2023, 08:41 AM   #2
Youngster's Avatar
I use the OEM air intake temp sensor on my Scangauge. Works great for my needs when driving. The only shortcoming to that approach is when in stop-go traffic the temp rises above ambient until moving again.
For camping I use a bluetooth thermometer puck that I access with my phone. The one I have is easy to use and can be calibrated.
2016 Beta 500 RS
2014 KTM 350 EXC-F
Youngster is offline   Reply With Quote
Old 01-26-2023, 08:11 PM   #3
I do the same. ^^^
Brian, I may have some info for you but need to ask someone I know first.
Ping me in a few days if I forget.
Old 01-27-2023, 08:27 AM   #4
aarcaris's Avatar
I have been using a Scangauge as well, but if someone finds a better solution, please share it on here or PM me your solution!
Vandit - 2013 E250 Ground Up Build
- Full Custom DIY Interior Build
- DIY U-Joint Off Road 6" 4x4 Conversion
aarcaris is offline   Reply With Quote
Old 01-27-2023, 09:21 AM   #5
Maybe I'm misunderstanding this but. My 2002 E350 ext window van has a factory outside temp gauge and a EWSN compass mounted in an overhead console, that seems very accurate.
This pic is from the same year F150 but you get the idea.
Old 01-27-2023, 10:58 AM   #6
BrianW's Avatar
@lilnuts2 that’s exactly what I’m talking about! I’ve heard of vans having that but have never seen one. Is yours a chateau, just a regular passenger, …?
The question is, where does the feed for this come from and can I maybe retrofit the OEM console from an F series, etc?
Old 01-27-2023, 12:18 PM   #7
On my old 2004 , I had a Gentex GENK20A Auto Dimming Mirror W/compass Temperature or similar added as an option
Old 01-27-2023, 02:01 PM   #8
Sadly I have never had my headliner out to trace the wiring for that temp gauge. Mine is a XLT van. I could be wrong but I don't think the Chateau was offered on anything but the E150s.
I would think either the E or the F system from a 2002 would work
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 01-28-2023, 12:08 PM   #9
You could get an E350 Chateau but I’m not sure if it was still possible by the time they changed it to the Traveler package in the mid 2000’s. All of the components are from F series/Excursion. A salvage yard Excursion is the most likely source for the overhead console and/ or a Windstar van. The temp gauge is right in the center top of grill in the neighborhood hood of the latch. The wiring is what I trying to track down. There’s a forum member who was fooling with this but I don’t know if he’s been active lately.
Old 01-29-2023, 08:30 AM   #10
vandiesel's Avatar
https://www.ebay.com/itm/15299801768...Bk9SR5iYr-K_YQ
Even better: https://www.ebay.com/itm/12548440750...pid=1325027109
Esme
Amy V
Rex
Tomboy
