Originally Posted by Stormy98
Unfortunately, no. The manual states:
The microprocessor has parameters for charging liquid electrolyte or gel cell batteries. The factory setting is for the typical liquid electrolyte battery.
And:
• Bulk Voltage- This is the maximum voltage at which the batteries will be charged during a normal charging cycle. The normal range is 2.367 to 2.4 volts per cell. For a 12 VDC battery (6 cells) this is 14.2 to 14.4. Liquid electrolyte batteries are usually set to the higher voltage, while gel cell batteries are set to the lower.
• Float Voltage- This is the voltage at which the batteries will be maintained after they have been charged. A range of 13.2 - 13.4 is appropriate for most sealed and non-sealed batteries.
• Absorption Stage- During this part of the charge cycle, the batteries are held at the bulk voltage and accept whatever current is required to maintain this voltage.
The method for selecting battery type is simply a jumper. No other controls. So it seems for the gel setting the bulk/absorption voltage is 14.2 and the float voltage is 13.2.
Would either setting (electrolyte or gel) be acceptable for LiFePo?
14.2-14.4 for absorb is fine..that's 3.55-3.6V per cell....the upper limit is 3.65V/cell for LiFePo4.
..and float at 13.4 is also fine..both of these are pretty much what most of us are running for LiFeP04.
There are two other things to think about, I think LiFeP04 likes a longer absorb time than typical lead acid or use a "tail current" method....this may be relatively minor.......I'm sure Scalf77 can shed more light here.
The other much more important parameter is equalization......I'm pretty sure gel profiles don't have this mode since they are sealed, but a flooded battery setting may use equalization. You don't want equalization with LiFePo4's since they are also sealed and don't need it.
If you can set bulk/absorb voltage at 14.2-14.4V and float around 13.4 without equalization (gel mode) you should be fine.
