Vincent here are several Vantage Optics Threads: FYIW:The HID's do require wiring in a ballast & the LED's do not - I've used both and you can't go wrong with either, but would recommend purchasing the side marker light replacements at the same time (also available from Vantage Optics): https://www.sportsmobileforum.com/fo...-14304-73.html (Last post has a current "Discount coupon code")
I thought I may have copied the link incorrectly, but when I open the link it shows the product with no problem...here it is again (and shows it is 'in-stock'): https://www.amazon.com/Parts-Go-1995...%2C105&sr=1-27
EDIT: Now Amazon has a message which appears across the top of my page that states " AmazonConfirmedFit: This does not fit 2006 Ford E-350 Super Duty".
I can only assume someone must have reported it doesn't fit, Yet I ordered these and they fit fine (& have been on my Van several years with no issue). Maybe they changed something over the past couple years. The ones you linked look good also.
Sure Vincent, I'll gladly order & ship again
Are you sure the link you supplied will fit your Van? I am no expert, but do not see any mention of an E-350 Econoline Van???
Being a considerably larger box than what the differential Bolts were shipped in, the shipping cost will probably be about the same price as the tail-lights...are you OK with that?
Also Vincent, PM me again about the Turbo - you sent me the links for 2 Web sites but they were for the 'home' page - you didn't specify what you wanted ordered.
Again, the weight and size on the turbo i'm guessing will run upwards of $250+ to ship to France.
Whatever parts you decide on, just order & Pay BUT have them shipped to my address (same as before), then I'll forward to you.
