OK, That is a standard Magnum inverter/charger with Remote Interface, and the BMK kit, that is the shunt and battery monitor. The information from the BMK is on the remote interface.
When I said both batteries, I mean both battery banks. You have the standard van electrical system, alternator , battery , starter, electrical distribution.
The house system looks like it includes you magnum inverter/charger and a battery bank made up of the two batteries parallel.
Normally, the easiest way to provide charging to the house system when driving is with the Surepower1315-200 separator or Blue Sea 762X ACR. There are others, but that was the most common for SMB, unless you are pre 2004 when they used surepower isolators.
Dual separate alternators was not a big option, that is why I question.
Wakespeed does have a harness, I would expect your existing alt would need to be modified, I am sure Nations could help with that. If going with Wakspeed it is best to make sure that they support your battery or more specifically the BMS. You can imagine that a BMS disconnect of the battery while the alternator was charging would not be a good thing.
