Old 11-19-2014, 06:59 PM   #711
WVvan's Avatar
Re: Hal The Van
I'd lean it a tad further forward if I could but the seat is at it's limit. Don't know about anyone else but this is what's comfortable for me. Even after riding for several hours.
OK, This is meant as a JOKE:
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
Old 11-28-2014, 04:44 PM   #712
BusDriverStu's Avatar
Re: Hal The Van
you're thread is absolutely amazing and a vital source of information for me as i am converting my astro in a home.
I was going to put down a plastic sheet over my floor also but I think i am sold on the rubber. Plywood seems a little heavy though, did you ever consider cork? Maybe cork is just as heavy if not more though.
BusDriverStu is offline   Reply With Quote
Old 11-28-2014, 05:59 PM   #713
WVvan's Avatar
Re: Hal The Van
Thanks. With the thickness of plywood I used it wasn't that heavy. I've never used cork but it's not rigid so won't the metal ridges from the van floor show through?
WWW.WVBIKE.ORG
Old 11-28-2014, 11:56 PM   #714
Re: Hal The Van
with the cork idea i was thinking of filling the gaps with reflectix then adding another layer of reflectix over the metal/reflectix alternating strips as an attempt to avoid impressions from the metal ridges. is there any reason you didn't do this? You seem to of gotten every spot imaginable with that reflectix! Great idea getting those door step spots also
but i do think after a little more research you probably had the right idea with rubber and not cork. I just found online "2mm rubber underlayment is equivalent in sound resistance to 6mm cork underlayment."
That leads me to another question - how thick is that base layer of rubber you got? I tried finding what you bought online at lowes' website but had no luck. Even went there to see if I could find anything close and had no luck, so it looks like ill have to source some online like you did.
Old 11-29-2014, 08:09 AM   #715
WVvan's Avatar
Re: Hal The Van
I didn't use reflectix on the floor since I had a layer of rigid foam.
This looks to be it the rubber flooring I used:
Amorim Rubber 4' x 10' Mat Flooring (Color: Black With Blue Flecks)
WWW.WVBIKE.ORG
Old 12-13-2014, 11:00 PM   #716
Re: Hal The Van
Nice work, sucks about the motor, I've done a few customers engines with bad intake gaskets putting coolant into the cylinder, causing hydraulic halt. One customer calls me can't get starter to turn, calls me later got it to crank but now has a rattle, bent rod! It usually starts with a check engine light for a miss as coolant fouls the plug
vanislevan is offline   Reply With Quote
Old 03-07-2015, 02:56 PM   #717
WVvan's Avatar
Re: Hal The Van
R.I.P. Tiger
1999 - 2015
Supervisor Extraordinaire
His companionship and his skills are both irreplaceable.
WWW.WVBIKE.ORG
Old 03-07-2015, 03:16 PM   #718
vwteleman's Avatar
Re: Hal The Van
My condolences.
Brent
Old 03-07-2015, 04:43 PM   #719
twogone's Avatar
Re: Hal The Van
heavy
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 03-07-2015, 05:07 PM   #720
Re: Hal The Van
Bummer. I always appreciated Tiger's critiques of your work. R.I.P. Tiger.
