Old 05-17-2016, 08:00 AM   #11
Originally Posted by 86Scotty View Post
Refrigeration coil (soft copper coil) and flare fittings are readily available at most hardware stores. Flare tools are pretty easy to use too.
I didn't flare anything from the tank to my Propex.......just used compression fittings with olives IIRC.....
boywonder is online now   Reply With Quote
Old 05-17-2016, 08:24 AM   #12
evy
evy's Avatar
ok thanks, is that white piece considered a cover?
DIY conversion build, extended 2010 Ford 5.4L E250 + high top, from Montreal Canada
evy is offline   Reply With Quote
Old 05-17-2016, 08:52 AM   #13
evy
evy's Avatar
Originally Posted by Pntyrmvr View Post
Salut!
On a besoin de quelque chose comme Extend-A-Stay Deluxe Propane Kit RV Camper - $77.99 .
Video shows it installed That way you can drain either tank or 20lb cylinder as you wish. And run a bbq from either one.
Bonne chance et prends des photos stp.
haha merci!
Did you install this thing on your setup?
If you want to see photos, click on pictures on top of this thread it will take you to my photobucket, you can view hundreds of them, have fun ;-)
Old 05-17-2016, 10:01 AM   #14
evy
evy's Avatar
What about this thing?
Do I just leave it like that?
it says "soulagement" which is french for "relief"
Old 05-17-2016, 12:47 PM   #15
Pntyrmvr's Avatar
Soulagement. Pour eviter les pressions excessif de propane. Laisse le la.
Je ne l'installe pas mais me les ai vu dans beaucoup de RVs aux EU qui rest longtemps dans un site de camp.
Old 05-17-2016, 12:50 PM   #16
Pntyrmvr's Avatar
Ton bonbomb coutait combien d'argent et qui l'a vendu?
Old 05-17-2016, 01:20 PM   #17
evy
evy's Avatar
haha what's a bonbomb?
Do you mean "une bonbonne"?
my lp gas tank?
If so I got it last summer and payed under 400$ online, don't remember where but I think PPL?
Right now it's at 419$ +10$ S&H
RV Propane Horizontal Tank on Sale - PPL Motor Homes
Old 05-17-2016, 01:46 PM   #18
Pntyrmvr's Avatar
LP gas Diagram, help needed.
Comment souvent a cette tete care ecrit le mot pour lp gas tank en francais? Oui ta bonbonne...
Dupuis looooongtemmmmps!
Old 05-17-2016, 01:48 PM   #19
Pntyrmvr's Avatar
Good price nonetheless.
Old 05-17-2016, 08:39 PM   #20
Evy: yes, the regulator has a white plastic cover.....
You should have a couple of fittings that are similar...as already mentioned one is a pressure relief, I think the other is for a Propane level gauge or level sending unit......which comes plugged off from manchester.
